Bennington RCW dual battery rewire - Blue Sea SI-ACR and switch added
I have a few questions about this pic.  What size wire did you use between each of the connections?  Is that plywood or starboard?  How did you mount your battery boxes to the floor?  I cant tell what some of those things are on your board?  fuses?  thanks.
I used the same as factory for all connections and re-used most everything already there. Added 4g for short runs. There are 3 Verado fuses on the board. It is cellular PVC trim from Home Depot. Works great. I bought new battery boxes since they were bigger group 31. Screwed to the ply deck with stainless screws.
2275 RCW Dual Battery Re-Wire
