No, just the duplex there on that circuit. I suppose I could put a GFCI there, I have a few lying around in the shop, but I'm not sure that it is necessary. That outlet is only hot when the generator is running, and when it is running it has something plugged into it. I'm careful with water, and that outlet is behind the access door. I need to look at the generator, seems like it has resettable breakers below the outlets, and they may well be GFCI.
