2011 SLI
Tommy24a
New owner, where can I get a wiring diagram for my pontoon? The switches stopped working, no horn, nav lights, radio, etc. The gages seem to work. It starts and runs well. The issue just started last weekend. Weekend before everything worked...HELP!!!!
Check your fuse at the battery, if it blows it will act the way you described. I believe it is a 20 amp fuse.
If this what you are looking at it is the circuit breaker for the accessories. It should have a button on one end for resetting. Always start at the beginning when chasing electrical problems. Hope this helps.
Interesting. Mine is an older boat. Maybe they changed it at some point. Or maybe it's a dealers choice setup?
