I have a 2014 20' Bennington SLM that has water coming through the floor causing the carpet to soak a 4' x 4' area to the left of driver pod storage. Anyone else have this happen ??? Dealer tried to say it was red ice chest in pic......wrong answer......no drain plug !!
Welcome to the forum raincoinc!!! First of all check to see if you have the aluminum underskinning on your boat. If you look under and you can see wood crossmembers all the way down from forward to back you don't have it installed. If that's the case when you are underway water is splashing up and hitting those crossmembers resulting in the boat surging and causing the water to somehow make it through and getting your carpet wet. The aluminum underskinning installed on those crossmembers makes for a flat surface and prevents water from coming into contact with them resulting in a smoother dry surge free ride......Do a search on this forum about the underskinning. There are a couple videos that members have posted that show exactly what I am talking about .....
