Thanks,
Our boat has a digital trim gauge and I need to set the max trim height. I probably should wait till the motor is raised. Has anyone had to setup the trim like this?
Thanks,
I have a 25Q swing back with the 350 Verado. I'm on the 3rd prop and the trim of course has been different with each setup. Originally the motor was mounted all the way down running a 15x15 enertia prop and the trim was from 2.0-2.2 at top speed of 50.5mph and 6500rpm's
Second setup was raised motor 2 holes and installed 16pitch enertia prop and trim was 1.8-2.0 and 52.5mph and 6480 rpms
currently running a 17 pitch enertia with motor still up 2 holes and trim is 1.7-1.9 and hit 53.4 mph but only turning 6200-6250 rpm's
The 17P prop got me the higher top speed but only when loaded light, if I'm loaded heavy the 16P prop was faster plus the holeshot suffered with the 17P. I'm planning to go back to the 16P enertia if I can't find another series to try.
Thanks for the help so far. We had a 2012 25Q with Yamaha 250. Just received our 2017 25RSB with 350 Verado. Just a miffed at performance between 250&350. 3-4 mph faster is unacceptable. Will try all recommended solutions!
Best on the Q was 46.
6300 rpm. First hole, all the way down. 15p prop. I'll be going up two holes and to a 16p. Will advise after that. Once again, thanks for the input.
What issues did you have with a heavy loaded front with 2 holes up?
