Welcome to Club Bennington
Login Register
Accessory Buttons
Discussion in 'Pontoon Forum' started by BVColley, Mar 14, 2019.
  1. BVColley
    BVColley New Member
    any suggestions on relabeling accessory toggle buttons that you can no longer read? Can they be purchased? Easy enough to replace? Thanks in advance
  2. Vikingstaff
    Vikingstaff Well-Known Member
    1,593
    2,105
    Dig around in these forums. There are a few different posts over the year about replacement toggle switches. Including websites for purchasing custom labeled switches. I’m sure someone will reply as a few members have them. Good luck!
  3. cwag911
    cwag911 Moderator
    5,995
    2,101
    Vikingstaff likes this.
  4. BVColley
    BVColley New Member
    Thanks!
  5. Peterson - Gunn
    Peterson - Gunn New Member
    7
    Hi folks - I have a 2015 SL 17. I installed a power bimini (more on that in another post) and instead of using their toggle switch I wanted to use a spare rocker switch already on my dash. I found https://rockerswitchpros.com/ and ordered six custom switches for around $8 each. They were easy to order, arrived in less than a week (!) and easy to install (you need their inexpensive tool). Highly recommend these switch covers - they have lots of logos/symbols/images to pick from and you can also choose your own words. The switch labeled RADIO is actually the accessory switch but since I only have one accessory - the radio - I relabeled it. The switches are translucent in the white area as you will notice because the LIGHTS switch is on.
    1trotter, Badger, Michiman and 3 others like this.
  6. Badger
    Badger Well-Known Member
    51
    97
    I also ordered new switch covers from Rocker Switch Pros to replace my 13 year old, faded rocker switch covers. One custom and and 5 from the stock selections. I din't get any of the novelty ones. Kinda wish I had though. Good company. Great service and fast delivery. Replacement is very easy with the tool.
  7. lakeliving
    lakeliving Well-Known Member
    7,711
    5,277
    My nav light one is starting to have the image scraping off. Might have to check them out.
  8. Vikingstaff
    1,593
    2,105
    Thanks for the resource. I have one accessory switch that is broken and will pop off. Was thinking of replacing it, or updating all of my switches to the fancier back and chrome looking ones.
  9. Badger
    51
    97
    The Rocker Pro switch covers are laser etched. So, no image to fade. Allows the back light to show through.
    Vikingstaff and lakeliving like this.
  10. Badger
    51
    97
    New Wire Marine is the sister company for stock (not custom) switch covers.
  11. Badger
    51
    97
    One more bit of info to add. If you order from both websites (stock and custom) and you let them know with a message when filling out your order they will combine the order for shipment, saving a few bucks on shipping costs.
Share This Page
