All Three Panel Gauges Dead?
Tooncrazy
Tellico Lake, TN
My 2015 2275 GCW Fuel, Tachometer and Trim gauges are all dead. Everything else electrical is working ok.
I don't see any loose or toasted wires behind the panel.
Is there a master fuse somewhere that might be the problem?
Can anyone give me some tips on what to look for to fix the problem?
Thank you.
Did you try the breakers ?
Do you have a Power distribution panel ?
All the little black round breakers on the console seem ok. I don't have a power distribution panel.
Thanks
Does anyone here have a schematic for a 2015 2275 GCW?
I located the schematic for my boat. It shows a 10 amp fuse between the ignition switch and the instrument cluster. I can't find this fuse. Does anyone here know where it is? Is there a fuse block somewhere behind the instrument cluster?
Thanks
I know this thread is a year old, but did you ever find that 10 Amp fuse? Went to take the Benny out today and all 3 gauges plus the hour meter were not working.
I'm having the same problem any answers on that 10 amp fuse I cant find it anywhere.
