sunedog
- Messages
- 530
- Reaction score
- 999
Thanks to everyone who took the time to post pictures and descriptions of adding an inset table base to the back porch of your boat to mount a grill. The hardest part is making the commitment to pull the trigger on the drill to cut a 3 1/2" hole in the deck of your beautiful boat. Once you start, there is no going back.
I just want to give everyone a heads up that when you drill the hole you may hit a hidden structural obstruction. My boat has underskinning in that area so I wasn't able to see what was beneath the floor. I did check it out as best as I could and concluded no wiring or control cables were running under where I planned to drill. But I got VERY VERY lucky when I drilled the 3 1/2" hole in the floor of my 2011 2275 GCW. As you can see below, I discovered some structural component I wasn't expecting to find.
I was able to fit my table base into this hole by using a wood rasp to enlarge the hole very slightly (maybe 1/4") on the side opposite the obstruction. Then I went out and bought a lottery ticket.
