Welcome to Club Bennington
Login Register
Bennington Washdown System
Discussion in 'Owners Chat: Options and Upgrades' started by Mike D, Jan 27, 2019.
  1. Mike D
    Mike D Member
    16
    Anyone have a pontoon with the washdown system? I see that my tritoon can have one under a seat next to helm, but its over 600 from benny. Wondering what all is in it and if anyone has pictures?
  2. Havasu
    Havasu Well-Known Member
    699
    563
    Fallbrook, California
    I have it on mine. Don't really use it much but it's nice to have. Mine is located near the rear countertop with the switch on the small "island" behind the captain's chair. The water reservoir is under the rear seat between the built-in cooler and power center.
  3. 1trotter
    1trotter Well-Known Member
    282
    311
    SOUTH CAROLINA
    I have it but rarely use it as well. Mine is under the passenger console.
  4. Mike D
    Mike D Member
    16
    any pictures or suggestions for adding one? I saw the Big Kahuna and its just ugly, not to mention out of place. was thinking of making my own under the passenger area. Maybe a 10" x 8" x 30" poly container and create my own hoses and fittings. I want it to wash off the dogs and the sand when we go out. just not wanting to pay 600+ from the dealer.
  5. Havasu
    699
    563
    It's put together pretty well but the switch location is questionable. Not really sure why they put it where it is on mine. Convenience I guess. I originally was going to move the switch and put an external sub in it's place. But, decided to put the additional sub under the rear seat and leave the switch as is.
    cwag911 likes this.
  6. Mike D
    Mike D Member
    16
    Thanks randy. Makes sense how it is designed now. not seeing one, i wondered. Any idea how many gallons the tank is? and how many GPM the pump runs? I think i can make my own version and save a ton....thanks for all your responses.
  7. Havasu
    699
    563
    The pump is a Pentair Shureflo 3.5 GPM. You can see it there next to the fill tank. Looking briefly online the cheapest I found them is around $106.
    I'm guessing the tank is approximately 2 gallons. I couldn't find any real specs on it but that's probably pretty close.
    I'm thinking if you did the install yourself the parts would run about $150-175.
    lakeliving likes this.
  8. Michiman
    Michiman Well-Known Member
    2,007
    1,441
    Okemos, MI
    My washdown is located in the front of the rear lounger, just behind the captain's chair. Of course, location will depend on your seating configuration. That said, we use our's on a fairly regular basis. Our's has a 12 gallon reservoir so you can do quite a bit of spraying. I did have to replace the spray head that came with it because it leaked (so did the warranty replacement) with one from the local hardware store.
  9. Vikingstaff
    Vikingstaff Well-Known Member
    1,400
    1,790
    Do you just want a wash down sprayer that can just pull in lake water, or are you looking for something with a refillable water tank to have clean water in? We were dissuaded by the cost of the Bennington spray down as well, but just wanted something for spraying off or down a periodic mess or spill. Per the recommendation of someone else on these forums back in 2016 we went with the following portable, easy to use, and very light washdown sprayer:
    Not sure if this meets your needs, but if so, it is cheap, portable, light and easy to use. Just don’t leave any water in it over colder months or it will freeze inside and ruin it. Otherwise, its easy to store and maintenance free.
    Dev75 and Michiman like this.
  10. prd2hnt
    prd2hnt Well-Known Member
    285
    203
    Kennard, NE
    We took a path similar to Jeff. Simple 2 gallon weed spray. Works well for what we need.
    Vikingstaff likes this.
  11. Richard Foisy
    Richard Foisy Active Member
    40
    141
    204C848C-7F6F-4DC9-A9DB-B7010EE3EA3E.jpeg 3A9B38D2-9E6B-4EAC-B486-B1F06C6CC2EC.jpeg I added one . Bought it from amazon. I used 1/2 pex for the suction line .it works great.
    gnc1017, joecfd1 and Vikingstaff like this.
  12. dannyleininger
    dannyleininger Well-Known Member
    160
    234
    Lake Wales Florida
    I have a 2018 SSX with the Sink Helm option and the Washdown option. One benefit of this “pair” of options is the sink is pressurized by the Washdown pump. No hand pumping. We have used this feature often, especially when fishing. I would do it again!
    Michiman, Vikingstaff and lakeliving like this.
  13. Michiman
    2,007
    1,441
    Okemos, MI
    Wow, I've never seen that option before. Very interesting placement.
  14. SEMPERFI8387
    SEMPERFI8387 Moderator
    9,500
    3,802
    York, Pa
    I wish they offered that in a “G elevated helm” option.
Share This Page
