Bilge Blower
Andy Lundsberg
My bilge blower stopped working and the little black reset button is not doing the trick. Any thoughts? When I turn on the switch, the switch does not light up so wondering if there is a fuse somewhere?
All other switches work just fine including the bilge pump which is located next to the blower switch on the ignition panel.
If you can get to the blower, give it a wack. If it works, the motor is going bad and should be replaced.
