Bilge pump
Larry anderson
I have 2007 Btritoon. I bought the boat 2 years ago I have water in the middle toon. When looking I found a bilge pump. It doesn’t seem to work its
On its side and water is over it I’ve set it up but nothing happens. Trying to find a on/off switch or a fuse. No luck can someone help
Me with this problem. Thanks
should be a switch on the dash to either turn it on or set it to turn on if the water gets too high.
On my boat its the switch on the far right.
Dumps the water back into the transom area ahead of outboard.
There's a couple of threads on this. Here's a link to one, which has a link to another:
http://club.benningtonmarine.com/threads/bilge-question.9688/post-127378
You'll note I also have a 2007 Tritoon. In addition to the bad fuse, I had a bad pump (and I'll bet you do too). Bought a new one at Academy Sports. Had to re-mount it with by basically gluing it to the bottom of the pontoon with a dark gray automotive adhesive (epoxy, I think).
I'm 6'2" and 235# on a good day - getting down inside that 'toon was fun!!!
Bilge pump has worked great ever since.
Note: there is no on/off switch for that bilge pump. It comes on automatically when the water level rises. That worries me, which is one reason I switch off the battery when I put her back in my covered storage.
