Bimini Top Frame
JimnPam
Hello, I am in need of a Bimini Frame for our 2016- SL20. Hit a low branch in a canal and bent the horizontal frame (which I somehow need to straighten) and the actual Bimini frame. Can't find one on line - HELP!
A Bennington dealer is your best bet .
You can try ,Great Lakes Skipper .
Contact your local Bennington Dealer, he can get the parts and repair
I just replaced one last winter and unless you change it completely out to an aftermarket one a dealer is your only solution
Have you considered if metal has mild distortions and not all ripped up to talk to a fabricator with tube bending equipment or even a fully equipped muffler shop. They can run those hydraulic benders with real minor changes as of course the aluminum is much softer than steel pipe. Maybe they have ability to weld aluminum (heliarc?) I purchased a front bimini frame from dealer and it was $600.
