Bimini top snap in rail
If you mean for the bimini, yes they are easy. You have to pull the top so it's tight and then they clip right in.
I had a little trouble with mine too, some of the new ones were molded a little tight, You could just get some new ones from the dealer or you can use a heat gun to soften them up a little and adjust them so they fit a little better.
