Wondering if anyone has experience selecting props at higher elevations? I hit 31 MPH at 5900 RPM WOT. Full fuel tank and two adults so a pretty light load. With a heavy load (4 adults, 2 teens, 2 kids, 2 coolers, more gear than needed) and Bimini up I don't lose much, maybe 1-2 MPH. I also boat at a little higher altitude, about 4500 ft. From my limited research I think that means I need to drop about two pitch sizes from what would be optimum at sea level.
Boat Model --------- 22' SSRCXP
Model Year --------- 2017
Tube Option -------- SPS, strakes on center tube and interior of outer tubes
Power Option ------- Evinrude ETEC 150 (Full Throttle Operating range 5300 to 6000 RPM)
Prop Specs --------- 3 Blade Stainless - 15 5/8 x 11p
I hit 31 MPH at 5900 RPM WOT. Full fuel tank two adults so a pretty light load. With a heavy load (4 adults, 2 teens, 2 kids, 2 coolers, more gear than needed) and Bimini up I don't lose much, maybe 1-2 MPH. I also boat at a little higher altitude, about 4500 ft. From my limited research I think that means I need to drop about two pitch sizes from what would be optimum at sea level.
I'm wondering if going to a 13 pitch prop would give me a little more top end, if there's something else I should check, or if that looks dialed in already? Honestly I don't need more speed for enjoyment, but if a small tweak can improve the performance I'd be silly not to try, right.
