truckone176
- Messages
- 25
- Reaction score
- 1
I have a 2275 RCW tritoon, my question to everyone is how do you get to the bottom of the 'toons to clean the gunk off. How do you lift the boat while on the trailer?
They work well for cleaning, note the boat is about 6” above the bunks.....
I had to pop the feet off to clear the trailer frame so it wasn’t as simple as it could have been. The other part of this adventure was I had a bad hydraulic leak and the boat ended up stuck up in the air until I made a 100 mile round trip to buy oil to fill the reservoir so I could drop it back on the trailer. Good Times! That being said, I plan on doing it again....Nice! I've never thought to lower them while on the trailer. I'll have to see if I can with mine.
Hi Jack, I attempt to clean mine in shallow water, (sandbar), how do you do the cleaning? Thanks.
I clean mine in the water at a sand bar .
I used White Diamond and a 10” buffer after using aluminum cleaner. Next time I plan to use something more aggressive and sharkhide at the end so the finish stays longer because it looks like crap already.What are you using to clean your tubes with? They look great! Mine are terrible....they are stained and look terrible....First pontoon boat here. I had a fiberglass boat for years I took really good care of but I bought this pontoon used and it's killing me that they look so bad!
