Cleats On Pontoon
I am on a private Lake only one driving pontoon
Our Lake Is Not Like Great Lakes
Could it be I am tying to tight and pulled rear only ??
Seems strange that only one side is angled right ??
The cleat it self looks parallel  with the bolt location .
Here is another pic
Same side
Cleat looks like it is at a 180
So this is the side that is angled at present
The end of season I will have dealer take a look
Do you think I could harm anything by using as is
Perhaps I should show dealer now
Hate to give the Boat up for minor repair if minor indeed
Boating Season Is Just Getting Under Way
It's a mystery, wish I had an answer for you.
Do you think one bolt broke and it rotated on the other good bolt?  Maybe even tightening it if it rotated the right way?
Just throwing out possibilities.
I looked at your picture as tightly as possible. The front horn looks longer than the rear. If you look at my picture, you get the same impression. It may have been angled last year.
Take a long handle, careful not to scratch anything, pace it through the eye of the cleat like a lever, and see if it moves when you pull or push it gently.  You should also see a ghost image of where the cleat "was" if it moved.
They are different style cleats ,Chucks are 4 bolt ,yours are 2
I appreciate all the help, weather is still not ideal but I will go down to the dock and see after I remove tie on if cleat is able to be moved by hand at least. It  seems strange that it would occur but I do feel confidant that it will be repaired under warranty if need be.
If loose I will see if I have access to bolts and may be able to tighten myself.
Strange that it would occur like I said on a small private Lake the current during the summer is seldom strong even during storms, the winter well the winds across the Lake are Brutal.
Strange but the mystery is solved I guess
Best news is I have nothing to worry about apparently
AS shown I have pics showing cleats when viewing Boat originally
The cleats in rear appear to be straight
Guess I was wrong
Since I was on the Boat I took a pic of the opposite side as well...........
So Both Rear Cleats Are Angled and Not Loose
I need to clean rails etc
Wanted dealer to clean but was told by the time boat got here uncovered it would need cleaned again
So I will be wiping the rails down with water and vinegar
Clean upholstery and carpet as well
They transport boat after cleaning without cover dust from road construction is all over interior so I get the pleasure of cleaning
Usually not a problem but with some health issues a burden
Good News Is The Benny is Perfect
Though No Explanation
Hey Pittsburgh, just so you know, the only thing holding the stainless cap on is the cleat. 2 years ago, I replaced 1 cleat because I rubbed a dock and I thought I bent the cleat. Turns out I had bent the stainless cap. 1 of the studs bent and broke the cleat. I straightened the cap with a 20 lb. sledge and bought a set of cleats on Amazon. The cleats were for a 4Winns speed boat but were exactly the same except for the stud size. Bennington used a bigger stud so I drilled and tapped the new cleat and installed larger studs. Those rear cleat nuts are a real bitch to get to, glad you didn't  have to deal with that.
What I Like About Bennington Most Is Their Warranty and Guarantee
In My Opinion The Best In The Industry
The Same Warranty For The Q - Series to The Basic S- Series (which is what I have)
Knowing It Would of Been Repaired Kept Me Happy and Cool
                 The Gold Standard of Pontoons
