FIRE UP
- Messages
- 129
- Reaction score
- 234
Hi gang,
Well, kind-a new here and, not sure if this is where to ask/post this. We have a new to us, 2014 Bennington 2550RCL or, 25L for short. It's fitted with the Yamaha 350HP V-8 and, a 16.25 x 17" Saltwater Series Polished Stainless Prop. Since we purchased it, about a little over a week ago, we've only had it out twice. Well, as I finished backing it in the garage the second time, I walked back to check on things and, what's this? A pink, frothy puddle on the floor, just below the tilt area. NOT GOOD! Well, that whole area, around both trim rams and, the power tilt ram, was wet with oil. So, I broke out my carb cleaner and sprayed that entire area and washed away all that residue. Within just a minute or two, it was dripping oil again, hmmmmm.
So, I sprayed it all down again and, walked around it and looked everywhere. I thought it was a seal at first. But, upon closer examination, you see in the picture what I found. It's a cracked PTT reservoir! Now, how in the world did/does this happen? Now, since this happened, I've dug around on line and found the service manual for my engine. It's the F-350A service manual. Basically, from what I've read in that service manual, there is NO PRESSURE in the reservoir, at any time. All the pressure is in the three rams, at various times. All the residual hydraulic oil, is sent back to the reservoir. kind-a makes sense there.
Now, based on the presentation of the "frothy" pink, I'm guessing that water infiltrated that system. Not a big deal. I mean, the reservoir has to be replaced anyways so, the system's gonna have to be flushed and bled. But, just wondering, have ANY of you, at least the ones reading this, EVER had the power tilt/trim plastic reservoir crack? This boat/engine had only 24 hours on it, when we purchased it. It now has a whopping 29.9 hours. See what you think.
Scott
Scott
