Has anyone else had or known of issues with the way Bennington installed their Baystar Hydraulic Steering System (type w/ tilt wheel & separate remote fill plug)? On mine, the remote fill port (small ~3/4" black cap that says "baystar oil only") is mounted on the flat area of the far outboard, forward, starboard side of the operator's console; because of this it actually sits LOWER than the fill port on the top of the helm pump that the fluid is supposed to go into.... If you try to add oil to the remote fill plug it appears full, but if you look under the console where the hose connecting the remote fill port to the actual fill port on the top of the helm pump is; the hose is only full of fluid right below the remote fill port and as the hose turns UP to go UP to the top of the helm it is only filled with air ?!!? I spent way too long today under the console trying to get fluid into the helm by disconnecting the remote fill and lifting the hose higher than the helm for it to flow down into and release the air bubbles - then repeated it about a dozen times till it was full - ALMOST 1/3 QUART LOW - even though it looked "full" at the remote fill? !?!? Am I nuts or does it seem like the remote fill should have been installed in a different (higher) location?
For reference; a figure from the Baystar manual is attached. #'s 4,5,6,7 & 8 all comprise what I am calling the 'remote fill port', #3 is the hose, and #1 is the fill port on the top of the helm itself.
FOR THE RECORD - THIS IS THE FIRST THING I HAVE EVERY FOUND W/ MY BENNI THAT SEEMS WRONG OR THAT I DON'T LIKE - SO I HOPE I AM WRONG - LOL !!!
