Electric Anchor
Louie13
How do I change the fuse for the anchor switch on a 2018 21SLX? The anchor switch doesn't light up.The accessories and lights switches next to it light up. I've pushed the reset buttons below the switch and on the anchor box with no results. I can see underneath the console it is a 5 amp fuse. I tried pulling that wiring black piece out but not sure how hard I should try! Not sure where the fuse is located. Thanks for any help.
If the anchor motor works and the only problem is the light not working, it is probably not the fuse. It will be a loose wire on the switch that is connected to the other switches or a bad light in the switch.
The motor is not working. Other thoughts?
Start with checking for power with a voltmeter.
Start at switch input side, then output side with switch “on”, then at anchor input, then at anchor motor. This will narrow down the culprit. It may not be a “power” issue, check your grounds also.
