farna
I changed the battery to my boat last year and accidentally connected the terminals backwards. Blew a fuse on the motor, all other fuses appear to be fine. A wiring diagram for a 1999 2275FS would be really appreciated! I have checked and made sure there is power under the console in the main harness. I'm about to go out and make sure I have power at the switch now. Anyone ever done this???
There are only two wires running from the battery to under the boat. Under the console there are two small sub harnesses going under the boat, one from the switch, the other from the motor controls, and another large (main?) harness. I can't find any fuses under the console other than the radio. Apparently everything splices together somewhere UNDER the darned boat! It's in the water, and I don't have a trailer. Will have to tow to a marina to get it out. I see that in the 2013 diagram posted in a sticky that there are circuit breakers on the dash. I will check to see if I have those on my 1999. I am familiar with vehicle wiring. I successfully grafted a 1988 EFI engine in my old 1963 Rambler wagon with few issues, but I had complete diagrams for both vehicles -- splicing 1988 into 1963 wasn't all that difficult. The circuit breakers I would assume are the automotive self-resetting type and shouldn't need resetting.
Any help would be appreciated!
