MrG
The Speedo on my Bravo 3 has been stuck or broken for some time. I finally said OK whats it gonna take. You Tube is your friend, I had to use this method. My Speedo was Jammed full of what looked like dryed out dirt It was real far up in the speedo hole. Thank goodness i had a extra long 8 inch drill bit I used to un-clog the speedo hole
but blowing air backwards threw the tube from the top of the outdrive down into the speedo tube with some warm soap did the trick.
I pretty much did the exact same thing this guy did
