Fusion Radio Fader with Kicker amp and sub
Bud Leary
When using the fader control on our '19 25 RCWX1's fusion stereo, the center position (balanced between front and rear) sounds ok (not great but ok)... front goes to all regular speakers with no sub and rear goes to just the kicker sub with no speakers. Does this sound correct or is it wired incorrectly ?
I know there are some real experts on here that can comment. In terms of just normal wiring, does not sound right at all given how it will interact then with controls, such as balance, etc... However, I don’t know if that is some quirky aspect of questionable pontoon wiring that just goes overlooked.
When did they start using Fusion radios?
No, that doesn't sound correct. Need some more info. Are you using an amp (which one) and is the sub passive or powered?
