tcpip95
I don't know if any of you are in the market for a GPS w/transducer, but West Marine has a great sale on the Garmin echoMAP 74sv with the GT51M-TM transducer. This is about $250 cheaper than anywhere else I've found. It comes with Garmin's BlueChart g2 maps, and the transducer uses high wide CHIRP sonar and Garmin CHIRP SideVü and Garmin CHIRP DownVü. The sonar transducer alone is about $500 and has side-scan and down-scan sonar.
I just ordered one and will have it installed while the boat is drydocked. This is the unit that also lets you create your own bottom-maps and contours using QuickDraw Contours (built-in).
Here's the link to WM:
https://www.westmarine.com/buy/garmin--echomap-chirp-74sv-fishfinder-chartplotter-with-chirp-sidev-clearv-and-bluechart-g2-maps--17044769
I had a $10 reward certificate to boot!
