1Blderbob
Yet another update: I heard back from the guy doing the work on my boat. The pontoons as they sit are in very bad shape. There's nothing that he can do. I'm going up the Saturday to pick up the boat.
Having said that, I found a metal fabrication company very nearby that have used TIG welding of a rolled aluminum "bottom cap" to the form a "jacket" around the pontoons. Apparently this problem that I have is not that unusual. The damage is below the waterline, so what they do is roll aluminum and make a cap that fits over the existing pontoons and then weld that to the pontoon itself. It's basically a sheet of aluminum that gets welded from "3 o'clock to 9 o'clock" the entire length of each of the pontoons. It ends up forming a thicker bottom (the old pontoon + the new sheet of aluminum welded to it), which forms an airtight and watertight seal right on top of the old pontoons. I will end up having a horizontal welding seam running the length of the pontoon (maybe I'll rename it Frankenton), but the boat will be safe and solid again. I still need to discuss with the shop whether they can do the lifting strakes and performance foils (forgot to ask them when I spoke with them), but I don't believe that will be a big problem.
So, sounds like it's going to be a few more weeks, but cost should be under $4,000 all told.
Good luck with the fix.I hope this will be the end of your adventure with the leaking pontoons.You sure have taught a bunch of us some don'ts and do's. Like to see pics of the end results.
