kent tapscott
- Messages
- 1
- Reaction score
- 0
my pontoon's ignition switch has started giving me problems. first the rubber grommet around the switch kind of "dissolved" and now the switch sometimes does not engage until after i turn it several times. once i use it, it generally works fine as long as i use it daily. If i don't used it for a couple of weeks, then it has the same issue all over again. I have discovered if i squirt wd40 in the switch it will fire right up----but evidently it evaporates and a couple of weeks without use and it must be turned multiple times again. the battery has plenty of voltage and that is not the issue. is there a fix for this? do i need to buy a new switch? does the switch match the boat or the installed engine? (dealer installed yamaha 115)? thanks for any suggestions!
