Welcome to Club Bennington
Login Register
Inflator for Tube
Discussion in 'Dock Talk' started by Dev75, May 19, 2017.
  1. Dev75
    Dev75 Well-Known Member
    145
    86
    NYS Finger Lakes Region - Skaneateles Lake
    I'm not happy with our air pump  - anyone suggest a good fast air pump?   Along with that question,  am I basically limiting myself to pumps that connect directly to the battery with clips if I want to inflate the tube quickly and to full capacity?
  2. mattb
    mattb Well-Known Member
    484
    315
    Central Ohio
    Overtons has a good line of pumps.  I have a 120v model that is very fast, but I also have an inverter on my boat for the 120.  Usually, the 12v models were a little underperforming compared to the 120v.  You can also plug into the 12v power port.
    Dev75 likes this.
  3. H2GO
    H2GO Well-Known Member
    104
    89
    Fenton MI
    Dev75 likes this.
  4. TomS
    TomS Well-Known Member
    2,883
    757
    Clear Lake IN
    We live on the water, so a bit different approach, but I use a small shop vac in blow mode to get it inflated and deflated quickly to ~90-95% on land, then use the 12v Overton's type on the boat to top it off and tight as needed.
  5. PonTuna Salad
    PonTuna Salad Well-Known Member
    122
    150
    Lake Norman, NC
    I have one that looks like a mini hair dryer that I have had for years. May have gotten it from target. Less than $20. Plugs into the accessory plug but came with an adapter that clipped to the battery.
    Pumps pretty fast, at least better than a reciprocating compressor.
    Vikingstaff and Dev75 like this.
  6. Jack M
    Jack M Moderator
    5,964
    1,309
    Petoskey Michigan
    I also use  a shop vac ,since we have close access to electricity at our marina . 2 gallon works fine ,never been used for anything but inflatables
  7. jmoreland
    jmoreland Active Member
    38
    26
  8. adkboater
    adkboater Well-Known Member
    727
    428
    Tylersport,Pa
  9. Dev75
    145
    86
    Thanks for the responses.  Never thought a pump could be so hit or miss depending on what you buy.  The one we have now is 12v but seems to take about 20 min to pump the tube.
  10. adkboater
    727
    428
    Tylersport,Pa
    We have a super slice tube and it takes about a minute or two to blow up, swap around the ends and it sucks it flat, fold it up and chuck it in the center storage.
  11. royal4
    royal4 Well-Known Member
    198
    86
    Jordan Lake, NC
  12. kaydano
    kaydano Well-Known Member
    3,628
    1,173
    For as much as we use our pump, it would be nice to permanently install one under a seat, then have one of those whole house vacuum setups where you just plug in the hose. It would be much quieter.
  13. Willb
    Willb Well-Known Member
    320
    92
    Logans Landing @ Indian Lake Ohio
    Inverter from harbor freight that's been on the boat for 4 years and a 120 pump from Amazon,  I like its ability to deflate.
    I use a lot of 3 person plus big heavy inflatables.
    Vikingstaff likes this.
Share This Page
