LED side lights
 sharse, LED strips will only work if the wires are hooked up correctly. If you happen to get the + to -, they won't come on, so to be sure before you cover all of your wiring, make sure they come on. It is suggested to just touch the wires together for a moment to make sure you have them correctly aligned. Good luck on your install.
You are correct, though. Red to red and black to black. There should also be a very small + on the strip by the wire where it comes out of the strip.
I purchased my lights from ezacdc.com
The connect right up.  The mounting is simple and the work fantastic!  Picture in gallery if you would like to take a look.
Same here.  Harness and everything was worth paying a little extra.
ALSO want to note that typical LED strips are MAX 16'.  the EZACD ones run the ENTIRE length of my 25' boat.  No breaks in lighting.. top quality product.
