Welcome to Club Bennington
Login Register
LIST YOUR SPECS HERE
Discussion in 'Members Zone: Props and Power' started by ericscher, Dec 7, 2011.
  1. Spoiledrotten
    1,767
    1,585
    Below the Mason/Dickson Line
    I must be incorrect on that. What's the set up called when you have the 3/4 toon in the middle?
    I changed it to EPP for Express Performance Package. Is that correct?
  2. RodEarl74
    RodEarl74 Well-Known Member
    139
    107
    • Boat Model --------- 25 QSB
    • Model Year --------- 2018
    • Tube Option -------- ESP PACKAGE
    • Power Option ----- Mercury Verado 350
    • Performance ------ 50.6MPH GPS AT 5950RPM
    WE HAD 3 PASSENGERS ON BOARD AND HALF TANK OF FUEL. BOTH BIMINI TOPS WERE UP AND THE WATER WAS CALM.
    MAY BE ABLE TO SQUEEZE ANOTHER FEW MPH OUT OF IT IF THE TOPS WERE DOWN!
  3. steven harp
    steven harp Active Member
    26
    24
    Waterford MI
    Hey RodEarl74, what prop are you using? I have a 18 25 RSB ESP w/Merc 300 and a 17p SS and only getting 44.8 @ 6150, 3/4 tank of gas.
    Michiman likes this.
  4. RodEarl74
    139
    107
    The standard prop the boat came with. It’s an Enertia SS I believe 17P
  5. JDB
    JDB Member
    11
    21
    2010 2275 FSI ESP
    Yamaha F250 Offshore Digital Elec. Controls
    15-1/2 x 17 3 blade saltwater series 2
    46 mph normal load
    3.2 MPG @ 20 cruise 1.7 mpg @ WOT
    Command Link Plus Digital Dash
    Sea Star Electric Power Steering
    Minn Kota Terrova 36 / 101 / i-Pilot
    5 Batteries
  6. Rick from Rocky Mount
    Rick from Rocky Mount Well-Known Member
    217
    342
    2018 25 QCW I/O with ESP package
    Volvo Penta V8 300hp with SS duo prop
    43 MPH at 5800 rpm (The Volvo Penta website states that the max rpm for this engine is 5800 rpm)
    2 adults with 1/2 tank of tank of gas
  7. Keith P
    Keith P Member
    15
    37
    Mullet Lake, MI
    Awesome. Do you know what prop and pitch you have?
    Vikingstaff likes this.
  8. Vikingstaff
    Vikingstaff Well-Known Member
    1,143
    1,383
    Hey Keith. I think I (Jeff) replied to your post on the FB Bennington page (Mercury Prop selector and this group). Glad to see you are here, and now I see you are in Michigan too. We are on Houghton Lake ourselves. Hoping you hear back on recommendations for your set up. Good luck!
    Keith P likes this.
  9. TwoTone
    TwoTone Well-Known Member
    76
    191
    Somewhere in Cabo... or Central Oregon...
    Current:
    • Model Year --------- 2019
    • Toon Package ------ ESP PACKAGE
    • Motor --------------- Mercury Verado 350
    • Performance ------- 47.2 GPS AT 6150RPM
    • Trimmed ------------ 2.7 Degrees (which is super shitty)
    • Prop ------------------15 Pitch Mirage X 15"
    The motor is mounted in the top hole, which puts the prop in the lowest position in the water...
    The boat is currently in the shop - I'm moving the motor to the 3rd hole which will raise it 3 plus inches and get the cavitation plate out from underneath the water line while planning...
    And changing the prop out to a 17 Pitch Enteria...
    This is going to be a real-time performance analysis...
    2 pretty big changes in both mounting position and Prop Pitch...
    I'm betting WOT will be 52 -55 afterward...
  10. cwag911
    cwag911 Moderator
    5,871
    1,945
    You might want to do 1 change at a time. IMHO.
    TwoTone, Vikingstaff and Renegade34 like this.
  11. RodEarl74
    139
    107
    Im running the standard prop that came on the boat. Mercury enertia 14.5x17p stainless. The Motor is mounted in the standard position. I've heard that if you move it up a couple of holes, you can gain another 3-5MPH! Not sure but I'll keep her right where she's at
  12. PierSki
    PierSki New Member
    3
    12
    Current:
    • Boat Model --------- 23 RSFB
    • Motor --------------- Mercury Verado Pro 250
    • I do not have all of the performance specs, had too much fun to pay attention. Now I have another reason to start the 2019 season, so I can compare performance with others.
  13. joecfd1
    joecfd1 Active Member
    31
    80
    Lake Havasu City, AZ.
    Spoiledrotten likes this.
  14. TwoTone
    76
    191
    I did Joe...
    In fact, it's Sun Country, Pat specifically, that is doing the changes...
    I'm flying back down on the 24th for a few days to run her again and see how the changes worked...
    Really great group of guys there...
    joecfd1 likes this.
  15. RodEarl74
    139
    107
    That’s where I purchased my Boat. I’ve had all my services done there and all prop work as well.
    They’ve always treated me right. They recommend the Enertia 14x17P prop for top end and the Revolution 4 Blade 14x17P for all around use. They suggest to move the Verado 350 up 3 holes for maximum WOT speed.
    I haven’t moved my motor upand don’t think I will. We don’t go WOT all that often and I’m happy with the near 50MPH I get with it where it’s at.
  16. TwoTone
    76
    191
    I agree with you in normal circumstances...
    I chose to do both at one time for a couple of reasons...
    1st - The boat would start to porpoise in all mid to high throttle ranges when I trimmed her out past 2.6 degrees...
    Under normal operating conditions she should trim out at around 5.0 - 6.0 degrees and should never porpoise...
    The tech there at Sun Country has been setting up Bennington's for 5 years and has a few hundred under his belt...
    He's confident that the motor is to low in the water...
    I did a test run after consulting with him to shoot a video of the cavitation plate, which should be at water level or slightly above when the boat is on plane - mine was buried...
    Hence the rise of two holes...
    2nd - The Prop change which was two-fold:
    He showed me in the Mercury manual, in really black and white language, that the boat should be running an Enteria and not a Mirage (which is what was on it)...
    Finally, the cat's meow was his personal log of the boats he has set up...
    The log showed the following stats:
    Year - Model - Engine - Prop - Mount Position (Hole) - WOT - RPM - Trim (@ WOT)
    The difference in my particular boat between a 15 pitch and a 17 pitch was night and day...
    To see all those numbers in black and white was a real treasure...
    He's installing the new prop next week and will be taking it on the water to test it out...
    I fly down on the 24th and can't wait to see the difference...
    For me, it's not really about the WOT speed - it's about the best overall performance...
    It's better for the boat and the motor...
  17. cwag911
    cwag911 Moderator
    5,871
    1,945
    Definitely agree on the Enertia. I love mine and it's on a Honda.
    Vikingstaff and joecfd1 like this.
  18. Michiman
    Michiman Well-Known Member
    1,817
    1,186
    Okemos, MI
    She's a beauty! I can certainly understand having too much fun on her...
  19. Keith P
    Keith P Member
    15
    37
    Mullet Lake, MI
    Two Tone: Great info. My dealer just set up my 2019 QX25. 350 Verado. He put on the Enertia 15 pitch and mounted the motor as low as it would go. Have to wait until spring to test it out.
  20. Vikingstaff
    1,143
    1,383
    Just my 2 cents, from a helpful suggestion:
    Your boat with a 350 Verado is going to be under pitched at 15. I think your dealer is going way too conservative on outfitting the prop and mounting the motor. Mine did as well, and it took a little bit of an assertive push, back and forth disagreement, and 2 days of trial and error to correct it after the fact when I first got our boat in the water. I’d avoid that process if possible.
    Thus, I’d strongly request 17p enertia for that 350 Verado. Second, I also really think that engine mount is going to be too low in the water, resulting in the issues mentioned above (too much drag). Due to boat similarities, I’d request (politely insist ;)) to start out with what Two Tone is switching too above. His changes sound much more apporpriate for that particular boat and motor.
Share This Page
