LIST YOUR SPECS HERE
I just prop tested it this last weekend. The 14p Enertia outperformed the 15p Enertia and both were better than my original 15p Rev4. The diameter of the 14p is slightly larger than the 15p (15.3 vs 15.0). All tested on the same day in the same conditions.
  • Boat Model --------- 21 SLX
  • Model Year --------- 2014
  • Tube Option -------- Two 25" Tubes w/Express Tube no strakes
  • Under Deck Wave Shield -------- Yes
  • Power Option ----- Yamaha F115la- 4-Stroke
  • Prop Specs ---------- 3 Blade Yamaha Pontoon Performance Series Stainless ,14x13
  • Performance ---------- 31.3 Mph @ 5800 Rpm ,speed on GPS ,
  • Full tank of fuel 21 gallons, 250lb of me, typical gear, dock bumpers down, whoops!
Quote
jfrack's BOAT:
  • Boat Model --------- 24 SCWX
  • Tube Option -------- SPS 150 3 tubes
  • Power Option ----- Mercury XDLR150 (25 inch transom)
  • Prop Specs ---------- 15X17 Aluminum
  • Performance ------ 42mph @ 5800rpm on GPS (My wife and I on the boat, full tank of gas)
Chris Z's Boat:
     Boat Model:  2275 GCW
     Model Year:  2014
     Tube Option:  32" Elliptical Perf Package w/lifting strakes and wave shield
     Power Option:  Yamaha F150
     Prop Spec:  Yamaha General Purpose Aluminium
     Performance:  38 mph @ 6000 rpm (gps) with 2 people and 1/2 tank of fuel on the boat
Sunnyside's Boat
  • Boat Model --------- 2375 RL
  • Tube Option --------  ESP (two 25" outer tubes, one 32" mid elliptical tube, strakes)
  • Power Option -----  2014 Evinrude ETEC 225HO, 25" Shaft, Mounted Hole #4
  • Prop Specs ---------- 3 Blade BRP REBEL SS 15.5"X17"
  • Performance ----------  46.5 mph at 5800 rpms (7% slip)
  • Loading --------Full tank of fuel 54 gallons, 2 people (350 lbs), typical gear
Jeff S's boat
  • Boat Model --------- 2250 GBR
  • Tube Option --------  ESP (3 tube - two 25" Tubes, mid elliptical tube, lifting strakes)
  • Power Option -----  2014 Yamaha F200XB
  • Prop Specs ---------- 3 Blade Yamaha Stainless 17"
  • Performance ----------  41.0 mph at 5800rpm
  • Loading --------Full tank of fuel 35 gallons, 2 people (400#)
    Notes - going to pitch down 1"...waiting for prop to come in. Boat is very heavy with options including the 53" pylon (I think weighs close to 90# with mounting hardware), refrigerator, 5 gallon water tank, power steering, extra battery, power bimini, scotch, rum, vodka, brandy, jack daniels, red wine, white wine, 30 cans of beer, coke, sprite, sour, tonic, seltzer, limes, lemons, cherries, olives, oranges, cutting board, ice, glassware, etc. Even with all that equipment and alcohol, it handles great. Max HP is 200, I'm very happy that I went all the way. I am confident a 150 will be a disappointment.
Boat:     2550 GSR
Year:     2015
Tubes:  ESP with sealed strakes
Power:  Merc verado 300 Pro
Prop:     Enertia 16
Perf:      48mph GPS at 6000rpm
Load:     2 people and half a tank of gas.
Notes: This was the very first run on a brand new motor. On second time out, with 4 people and full tank of gas plus cooler etc, 47mph at approximately 5900 rpm. Upon break in, proper trim and operator gaining experience, I will update.
Boat:     2550 GSR
Year:     2015
Prop:     Enertia 16
That looks great. You might be able to run a 17 or even an 18, which is what I have. Wait until 20 hours and check it out. 6400 is upper limit on the V-Rod. Mine turns about 6250 with the 18 on a 250 Pro.
How did that happen?
Big Blocks Specs
Boat Model:      2575 QCW I/O
Model Year:      2014
Tubes:               ESP with Sealed Lifting Strakes, Under Deck Wave Shield
Power:               502 HO (430 hp)
Drive:                 Bravo III X
Props:                Bravo III XR Pro, 27 Pitch
Load:                  Normal Gear, 1 Adult (165lbs), 36 gallons fuel
Performance:    57.2 GPS @ 4,950 RPM
Big Blocks Specs
Model Year: 2014
Drive: Bravo III X
Nick's Boat
  • Boat Model --------- 2275 GCW
  • Model Year --------- 2013
  • Tube Option --------  ESP w/56 gallon tank
  • Power Option -----  2013 Yamaha F200XA, 3.3L v6, lowest mounting position
  • Prop Specs ---------- Yamaha Saltwater Series II, 15-3/4 x 15P, Polished Stainless Steel
Light Load Specs:
  • Performance ----------  39.5mph @6000 RPM - Elevation: 4,484'
  • Loading -------- Light load, 2 adults, ~15-20 gallons of gas
  • Notes ------- Optimum trim level was around 1/2. Porpoising would occur between 1/2 and 3/4. Pretty smooth water but not glass.
Heavy Load Specs:
  • Performance ----------  35.2mph @5600 RPM - Elevation: 3,606'
  • Loading -------- 5 adults, 2 dogs, ~56 gallons of fuel, 2 massive 120qt coolers, food, water and camping supplies for a 5+ day camping trip.
  • Notes ------- Optimum trim was once again around 1/2. No porpoising above that but speed would slip. Slightly choppy water conditions.
I think I am propped just about right and I am very happy that my top speed didn't slip a huge amount with the heavy camping load. I had hoped to do a light load test at the lower elevation but I didn't get around to it. Maybe later this year.
GNC1017's BOAT:
  • Boat Model --------- 2575 RCWCP
  • Model Year --------- 2015
  • Tube Option -------- ESP (standard with unsealed strakes and performance foils)
  • Power Option ----- Yamaha 250 SHO
  • Prop Specs ---------- 3 Blade Yamaha Saltwater Series II SDS 15 3/4 x 15
  • Load ---------- 3 adults (~600 lbs total), ~28 gal fuel, typical gear
  • Performance ------ 42mph @ 6000rpm, motor in hole 1 (new, clean boat, just after initial 2 hour, low-RPM motor break-in session)
Anyone running or tried running a Yamaha SHO with SWS II prop on an ESP package in hole 2? If so, curious if you get ventilation in tight turns.
  • Boat Model --------- 20 SLX
Tube Option -------- SPS (strakes and performance foils)
Power Option ----- Yamaha F115XB
Prop Specs ---------- 3 Blade aluminum 13.25 x 17
Load ---------- 2 adults - 32 gallons of fuel
Performance ------ 35 mph @ 5900 RPMs
  • Boat Model --------- 22 SFX APG
  • Tube Option -------- Twin Ellipticals
  • Power Option ----- Mercury 150
  • Prop Specs ---------- 3 Blade SS Enertia 14p
  • Load ---------- 2 adults - 16 gallons of fuel
  • Performance ------ 38 mph @ 5800 RPMs
GL2075
2013
Twin Elliptical lifting stakes
Etec 115
Hydrus 13 3/4  x  13
Two adults light gear 30 gal fuel
31.4 MPH @ 5800  WOT
  • Boat Model --------- 2350 RSR
  • Power Option ----- Yamaha F300XCA
  • Prop Specs ---------- Yamaha Salt Water Series II 15.5 x 17
  • Light Load ---------- 1 adult - 25 gallons of fuel (~1200')
  • Performance ------ 48.5 mph @ 5800
  • Moderate Load ---------4 adults 1 kid - 36 gallons of fuel (~1200')
  • Performance ---------- 46 mph @ 5600
  • Boat Model --------- 24 SLX
Model Year --------- 2016
Power Option ----- Yamaha F200XB
Prop Specs ---------- Yamaha Reliance 14 1/4" x 17m
  • Light Load ---------- 1 adult - 20 gallons fuel
Performance ------ 42.0 mph @ 5800
  • Moderate Load --------- TBD
Performance ---------- TBD
  • Model Year --------- 2016
  • Power Option ----- Yamaha F200XB
  • Prop Specs ---------- Yamaha Reliance 14 1/4" x 17m
  • Performance ------ 42.0 mph @ 5800
Update:
  • Moderate Load --------- 3 adults - 20 gallons fuel
  • Performance ---------- 42.0 mph @ 5500  (after 20 dealer service)
