Livewell- Question
Michael Lyman
Northeast Ohio
I have a 2016 21 SLX that I just bought this past winter. Quick Question:
  • Livewell is in bow of boat top right
  • Black plastic with a drain plug at the bottom
  • I have a switch by steering wheel that goes on and off
Trying to figure out what the switch does? Thanks for the quick help, know it must be something simple.
The switch by the steering wheel turns on/off the Bait Well Pump. The yellowish/white tube coming out of the side of the Bait Well is where the water squirts out from...but you must open the valve by turning the end Counter-clockwise. There should also be a white tube with threads on the bottom and this screws into the bottom drain and is the drain when the Bait Well is full. If you look at the bottom of the Left (Port) tube in the rear you should see the pump. I used this bait well for the last week while fishing in the Florida Keys. Work very well.
if the white tube with threads is missing, then the live-well will never fill.
