Interesting question. If you are willing to drill a hole in your boat (don't worry, there already are hundreds of them) you might consider something like a fire safe bolted through the floor (or screwed into the floor) inside one of the seat compartments. Another option would be to use some kind of adhesive and just glue it down. Carl knows some 3M stuff that might work, I don't recall the name off hand. 3000-something??? Someone could pry it out, but odds are they wouldn't work that hard and they'd probably assume it was bolted down and move on. Glue is an option if you don't want to drill holes. If you glued it down, you wouldn't have to worry about water getting in.
