Looking for a console light
20072075gl
Good afternoon all, looking tor one of these fancy push button lights for my 2007 2075gl can’t find it anywhere. Dealer says no go... anyone have any links or options they would use?
Thank you Baja 252! Have you used this light before? Does it cover the same location? Using same screw locations? Will I need to cut it out any to recess it in?
I haven't used it. I was just looking on Amazon and thought it looked like the one in your photo.
If you not trying to match it to your photo, I saw a lot of other LED courtesy lights with chrome bezels on Amazon that look pretty nice too.
Awesome thank you, trying to get something close, I ordered one to see what it’s like, it should work. Better than the crumbling one on there now.
Did the light you ordered work? I am having the same problem with the exact same light.
It did, I ordered mine in white and I had to enlarge the opening slightly more egg shaped. Worked very well. I used a dremel to hone it out make sure to have a shop vac handy it makes a mess! Hope it helps!
