Macon_a_Splash
This is a great site. I've spent some time (okay, lots and lots of time!!) reading old posts and trying to figure out what I was going to do. In the beginning, I was just going to do a little research and check out a boat show and be ready to either buy a great boat this spring or wait and order what I wanted next year'ish.
But did I mention I went to the boat show?!? And then all thoughts of later sailed away and I wanted to be sure I had MY boat THIS summer, not sometime later. Carpe diem! So, without asking for the wisdom of the group, and feeling confident because of my reading time here, I went ahead and pulled the trigger a few days ago. Now I'm wishing I had gotten some other opinions about some of the options. I probably have a few days (my boat dealer has been nice, but I wouldn't want to push it) that I could change small things. So, better late than never, I wanted to tap into the brain trust here to see what you all have to say.
Boat use: Primarily will use the boat for cruising with just a few - but I do like to get from point A to B sooner rather than later. There will be several weekends over the summer that it will be a big group who will want to boat and tube and ski. No hardcore fishing, but want the option to look "busy" as I float aimlessly - so some very occasional fishing without much gear. Of course, my boat needs to look gorgeous!
I am limited in space to what my current boathouse will allow. My slip measures 10'6" wide by 20'8" long although my roof overhangs the end of my slip by another 2' - so a little more than 22' in length of roofed space. So my size options and model options are limited.
As it is, the one I ordered will be longer than my actual slip, but should fit under the roof (except maybe part of the engine). I think the LOA of this build 21'11". Anyone think this sounds like a problem? My boat dealer thought it would be ok.
Here's what I ordered:
21 SLXP / extended aft deck / Yamaha 150HP / SPS w/transom fuel package
Colors
Smokey granite with midnight black accent
Sandstone upholstery (80% cut out) with carbon accent
Zebrawood slate
Seagrass slate floor
Options
Elevated helm
Stainless dock lights
Recliner upgrade R series caption chair
Heavy duty rub rail
ski tow bar (not the turbo swing)
kicker KMC10 Stereo upgrade
battery - single switch
electric bimini
RGB toe kick lighting/cupholder lighting/side illumination
Table upgrade to rectangular
a couple of portable cupholders
privacy enclosure
Simrad G05
4 pole rod holder
Questions
I exercised very little fiscal discipline, but it felt good to say "no" about something, so I didn't spring for the underwater lighting (could add later) or the center toon storage (can't add later).) But I'm curious if others would swap out something above for one of these options or something else? How much storage will I have without the center toon?
I also struggled to decide between the Simrad and the Garmin option - really couldn't find good information as to exactly what the differences are - I am not an experienced boater and some of the descriptions were lost on me. What's the difference? I want something that will help me find my way home - especially at night - not a big lake, but I haven't yet figured out the landmarks. Depth, water temp and speed are good to know as well. I don't really care about its ability to find fish - the pole typically will dangle just to give the appearance of something other than pure lazy idleness. Haha.
What's the difference between the "single switch" for the battery and the "master power switch S/G".
Any pics of my build/colors? I've had trouble finding pics of the colors I chose - haven't seen the combo in real life and I've kinda panicked the past day or so wondering if I'm going to love it. If anyone has pics of these colors, I'd really appreciate seeing it.
Safe to pull a tube with a ski tow bar? I won't be pulling a tube that often, but on the days I do, I certainly want it to be safe. I've seen some posts that discuss whether the ski tow bar is okay for pulling a tube. There is a post where TB weighed in and says its ok - but it's a post from a couple of years ago. There isn't any info in the Bennington brochure that says what the limits of the "ski tow bar" are. The Bennington website has a number of photos showing tubes being pulled with a ski tow bar. I wouldn't expect Bennington to show those if it wasn't totally safe.
Thanks so much for any help and reassurance you all may have!
Colors
Zebrawood slate
Options
Elevated helm
Heavy duty rub rail
electric bimini
privacy enclosure
Simrad G05
4 pole rod holder
Questions
