Lucas Oil Fuel injector cleaner
MrG
Lake Tulloch Ca
46E40709-B36C-463C-A049-59368172C022.png I was getting a system fault warning on my dashboard. I have a 2012 25 QCW with the Merc V8 and Bravo 3 outdrive. My boat was idling very rough & missing at the end of a long idle up river. Under a load the boat team fine. I got a “ODB System Fault” error on my dash. It’s been like this for a few days.
I was at the local Shell station and they had this on the counter. And to say I was skeptical we’ll????. I mean come on anything that says “tuneup in a bottle“ has got to be a joke, it might as well have said “ as seen on TV” Well for $4 dollars a bottle I bought two of them (says one $4 bottle treats 20 gallons) I figured $8 dollars it’s worth a try. I filled the boat up and put 2 of these in.
Well I’m happy to report the engine Missing & ODB Fault is GONE. :) I can’t believe it. Just thought I would report my results, not sure it will work for you, but if your having the same issues give it a try. I know some people swear by other fuel additives, but this is the first time I have poured somthing into my fuel that it actually did what it said it would do! The gods must be happy with me :)
https://www.amazon.com/Lucas-Oil-LUC10020-Ounce-Treatment/dp/B0006305RY/ref=mp_s_a_1_6?keywords=lucas+oil+fuel+injector+cleaner&qid=1565198787&s=gateway&sprefix=Lucas+oil+fuel+injector+cleaner&sr=8-6
SEMPERFI8387
York, Pa
Lucas is good stuff. They make all kinds of additives and I’d swear by them!
Michiman
Okemos, MI
MrG, thanks for sharing your story. Hopefully none of us will encounter a similar situation but if we do...
BigKahuna
North Carolina
I use Seafoam at least once a season. It basically does the same thing......
jhill
Portland, Oregon
I use Lucas 2 cycle oil in my Echo weedeater mixed 20% stronger than recommended. I run it hard and can't remember ever changing spark plug and it is like 10 plus years old. I looked at exhaust screen and looks like it was just cleaned . Doesn't even have any noticeable smoke. Lucas products are great!!!
Shmily
I put Yamalube RingFree in every tank. My friend and neighbor here at the lake has used that in his Yamaha for 15 trouble-free years, so I do the same per his recommendation.
jhill
Portland, Oregon
Is that a lubricant or injector cleaner? I had not heard of it. Sounds like a great idea! Is it available online?
SEMPERFI8387
York, Pa
Yup, use this too. It’s a fuel conditioner also, but I still use Stabil.
