Michiman
Hey Jeff, never owned a lift but it seems like burying the supports even a few inches would make it that much more difficult to remove the lift at the end of the season. Hope my logic doesn't hold up...
Okay thinking a little outside the box.......If you're willing to spend $7500 on Sea legs and another $3000 on a canopy........How much would it be to have someone come in and dredge the area that you need to comfortably use the existing lift ??? Just a thought........
That's something to definitely keep in mind!There are also a couple of Benningtons with Sea Legs at the south shore sandbar. I know one owner wasn't happy with them because it didn't raise his pontoon high enough out of the water for the high winds when he docked it in front of his house.
So my latest update on the lake level issue is we moved the lift out to deeper water today. That was much more work than I had thought it would be.
In the pick below you can see our lonely lift 250’ out from the shoreline. After messing with it today, walking in and out from it, etc, I can tell you the decision is certainly starting to lean towards trying to add on Sea Legs next year.
How do the pontoons next to you get off their lifts?
If that’s the option I’d be signed up for sea legs!! I may be a speed demon( for it can be!) but there’s no way I’d be in the water every time, maybe a dingy to tie up to the lift? String a rope between and pull yourself between the two???
I’m sure you could find a small little boat even if it had oars and just set the lift up so it can be tied off quickly and easily. I’m assuming you can still pull up to your dock just the lift won’t work?
