Welcome to Club Bennington
Login Register
motor mounting height?
Discussion in 'Technical Stuff' started by 2fast4u, Oct 15, 2017.
  1. 2fast4u
    2fast4u Well-Known Member
    50
    32
    central North Carolina
    What motor mounting height is best for a 2250 GL with twin 25" round pontoons? My motor is a Yamaha f115. Currently it is mounted as low as possible on the transom. Thanks
  2. lakeliving
    lakeliving Well-Known Member
    7,113
    3,867
    Palm City Florida
    Leave it there. You won't see a change worth while raising it.
    cwag911 likes this.
  3. 2fast4u
    50
    32
    Thanks, Mabe others will chime in on my question with some other advise!
  4. adkboater
    adkboater Well-Known Member
    1,203
    907
    Tylersport,Pa
    Andy is correct unless you have lifting strakes, the anti-cavitation plate should be just at the top edge of the water when on plane, hence the lifting strakes. If the motor is extremely deep in the water you may see a little quicker pick up by raising it up but not the numbers you see on here related to the triple toons etc. without lifting strakes you just have a displacement hull.
    lakeliving and cwag911 like this.
Share This Page
