TexAgg56, thanks for the reply. I don't own a Bennington and currently fish with a center console and have 3 rod holders mounted to each side of my 22 ft boat. Wife and I would like to have a fishing pontoon but it's got to accommodate our fishing style.Most rail mounted rod holders get in the way of the mooring cover. On my Benny, even if I removed the rod holding part, some of them unclip and can be removed. The actual mounting bracket itself got in the way of the cover. I do not have a "fishing" version floorplan. I still haven't found anything that will permanently mount on the rail that does not interfere with my cover. When I say interfere, it stretches the cover way too tight to fit around the mounting bracket. Mine is super tight anyway. Thus, putting too much strain on the snaps. For rod storage and transport I have the SS tubes that attache to my tow bar. 3 on each side.
Dannie, thanks. I have indoor storage so don't know that I would use a mooring cover. Do you think it would be possible to use the Scotty bolt on type brackets (they go around the tubing)? I'd like to use what I already have if possible.I use these on the side panel of my Benny. Just take them of when you put the mooring cover back on.
https://www.amazon.com/Eagle-Claw-AABRH-Clamp-Aluminum/dp/B0084EG224
Yes, I meant the rails when I wrote "tubes"..I bait fish and usually have 6 rods baited (3 each side). I also have two electric downriggers that I would want to rig but that's another discussion. I would appreciate any pics/input.When you say the tubes, are you talking about the fence rails? If so, are you bait fishing, or trolling? I clamp mine under the upper fence rail to the siding. It holds well enough to troll with ( no down rigger ). I personally don't want to drill any holes in my boat. I am working on a clamp on down rigger attachment to go on the cleat. If you would like a photo of the fishing rod holder, I can snap one on Saturday.
thanks for the info. If you have mounts attached to the rails without bolting them on, what keeps them attached?I have my Scotty mounts mounted to Bimini arms and I also place them on my rails without bolting them on. They hold strong. I also have a mount on my transom that can hold a single or triple rod holder from Scotty. I also have a Scotty mount near my throttle that uses a Scotty cup holder being the throttle hits the cup.
