Hey guys!
I've been looking through all the old threads on boat grills lately trying to figure out what I wanted to put on my new boat. The Magma grills look awesome, but since I'll usually be out on my boat camping for 5-7 days at a time, I wanted something a bit more versatile so I can cook things in pots and pans and grill at the same time. I decided to buy a Coleman Roadtrip XLE and Arnall's Grill Bracket Set and do up a custom boat grill. The Roadtrip grill has removable griddles so I can replace one side with a pot burner attachment. It's a bit bigger than most boat grills I've seen, and definitely larger than what I was able to find others had mounted with Arnall's brackets, but it seems to have worked out pretty well. I removed the folding legs which is just one bolt. I swapped the nut on that bolt for a wing nut so if I want, I can stow the legs and still use it on the beach. The mounting brackets don't interfere with the legs. I only had to drill two holes into the grill but it was easy. The side trays were hitting the bolts when they would slide in and out so I used a grinder and just took out a little bit of plastic on the underside of them where no one will ever see and they slide smoothly now. I won't know for sure until I get it out on the water, but so far, so good. My biggest worry is rough water as it does bounce a bit when I stomp around on the boat. I'll report back after more testing. Time to go cook lunch on the boat in the back yard!
Pics:
Pics:
