jhill
I guess living in a mild climate like Portland, Oregon has its benefits. Our winters might hit 20 degrees for a week and maybe 3-4 inches of snow total in average year. The rest of the time in high 30's to low 50's. I was told by Bennington dealer to just add winter fuel stabilizer to fuel tank that is under half full after last trip of summer. Run it enough to have treated fuel in engine injection system. Leave outboard all the way down in operating vertical position and it will self drain. Turn off battery switch. Trickle charge batteries a few times over winter. Done! Ours is on trailer and backed under 14' W x 40' L x 12' tall walls VersaTube kit RV shelter so stays under a roof. Change quality oil and filter at maximum 100 hours. Put mooring cover on it when entire inside bone dry. If you are only putting on 30 or less hours a year, I think some professional "winterizing" in mild climate is overkill. Of course eventually needs lower unit oil change, water pump impeller, fuel filters, spark plug change, etc. Keep track of hours and service per manufacturer specs. We only use in freshwater. I bought my 2013 22 SLX in 2017 and traded it in February 2020 and was just coming up on the 100 hour since dealer did oil change before we bought it. No service costs at all. This used 2017 22 SSRCX had 29.5 hours in February (dealer changed oil as they routinely do on trade ins before reselling) and now about 50 hours total after summer use. Am I so wrong in my service strategy? Fuel injection and electronic ignition solves so many old carburetor and choke issues that used to be common with outboards. What are your thoughts?
