Trim would still work. Fuse under the motor cowling?Safety lanyard?
I'm not understanding, are you saying you checked the fuse on the actual motor under the cowling and it is good?fuses under the cowling, 10 amp under the dash for engine is good???
Remember the fuse problem we had a couple years ago? (How could you forget You towed us) Our mechanic checked the fuse in question with a meter and it was "good". Later he found the hairline crack on the side.Make sure you check the fuses with a test light or a meter. I have been burned by "looking" at a fuse.
