sparkdr220
- Messages
- 111
- Reaction score
- 7
The output depends on the size. Mine is about 18 inches square and puts out 4-6 watts. It acts like a trickle charger.
Thanks SemperFi... I appreciate "keeping it real", and I love my boat to death and hope to trade up through the years. However, whether I buy a $15,000 Chevy or a $60,000 Cadillac, I expect them to come with a speedometer, voltmeter, fuel gauge, oil pressure gauge, water temperature gauge. You know, the things that help you run and maintain your machine properly and don't find yourself broken down on the side of the road. I personally would expect the same for my boat. Maybe I am not the normal buyer... I looked at several other boatlines in this price range and they all seemed to have a better gauge package (not the Bennington quality though!!!!). That is my one and only dislike on this boat. Maybe it is because I operated an I/O for 20 years, but I like monitoring my boat's behavior. I had the opportunity to upgrade the captain's chair, carpeting, speakers, table, toon size, etc. I wish I would have had the same opportunity to upgrade to a gauge package that helps me keep an eye on my motor (maybe I did, and I just missed it).Please keep in mind, the S is a base model economical package. This is an entry model that is built to keep budget as low as possible. Blaming them for this is like me blaming them my R does not have Q seating .... Just my 2 cents .... Keepin it real !!!! LOL !!!!
I am buying an "R" series with Mercury Smartcraft and I have to agree here. It has just the 2 large multi-gauge spots for a big hp outboard. Having to find and scroll through a menu just to see fuel, trim, water pressure/temp is not acceptable IMHO. It may look really nice but it is functionally sub par in a product that is otherwise beyond reproach and best in class.Thanks SemperFi... I appreciate "keeping it real", and I love my boat to death and hope to trade up through the years. However, whether I buy a $15,000 Chevy or a $60,000 Cadillac, I expect them to come with a speedometer, voltmeter, fuel gauge, oil pressure gauge, water temperature gauge. You know, the things that help you run and maintain your machine properly and don't find yourself broken down on the side of the road. I personally would expect the same for my boat. Maybe I am not the normal buyer... I looked at several other boatlines in this price range and they all seemed to have a better gauge package (not the Bennington quality though!!!!). That is my one and only dislike on this boat. Maybe it is because I operated an I/O for 20 years, but I like monitoring my boat's behavior. I had the opportunity to upgrade the captain's chair, carpeting, speakers, table, toon size, etc. I wish I would have had the same opportunity to upgrade to a gauge package that helps me keep an eye on my motor (maybe I did, and I just missed it).
I have a Yamaha and am aware of the "smart gauges" out there that would fit (swap into) the existing spots on my console. However, #1 they cost $100's of dollars compared to a single gage and #2 they don't look the same as the existing gauges (mismatched look on the console seems unattractive to me). I don't really want to put a new hole in plain view with the existing gauges, so I really like where you put the Water Pressure Gauge on yours. If I get the battery meter that plugs into the power outlet as suggested by Kaydano, then I would have that covered as I could plug it in every now and then to check things out. That would give me the factory installed RPM & hour meter, trim gauge, and fuel gauge, the plug in voltmeter, and a water pressure gauge tucked away off to the side. The only thing missing that I would want would be an oil pressure gauge. However, when I discussed the smart gauges with my dealer/service guy, he thought I was just being an overconcerned ninny as "nothing goes wrong with an outboard" (especially as related to the I/O's I've had). However, I had an intermittent dummy horn sounding at the beginning of last season. When I checked my oil the level was OK, and I could see water pissing out the side of the motor. So, would have been nice to have gauges to give me more info to determine if I had a problem. Any feeling on the value (or non-value) of an oil pressure gauge? Any other out of the way places to put an extra gauge?Hey Vin, what brand motor do you have? Maybe you should invest in a "smart guage" which will monitor all engine functions for you. They're not that hard to install.
Vin,
Do you have a GPS, and if so, is it NMEA-2000 compatible? I have a Garmin 541S that has a NMEA-2000 interface. I was able to buy an adapter cable that plugs into my Yamaha F150 (about $95) and plugs into a basic NMEA-2000 starter network kit (about $80) and it gives me the following info on my Garmin:
NMEA 2000 Yamaha Engines output the following standard data:
• Engine RPM
• Boost Pressure
• Engine Trim: 2006 and later
• Oil Pressure
• Engine Temp: 2006 and later
• Alternator Voltage
• Fuel Rate
• Hours Used
• Water Pressure
• Fuel Economy
I don't need to have the Yamaha CommandLink to do this.
