Yet another prop question for the group. This one is a little different than usual though. First off, here are my boat and prop specs from last year in the specs thread:
Nick's Boat
Light Load Specs:
Heavy Load Specs:
So here's the question... I've noticed that with really heavy loads, I'm now seeing my RPMs down in the 5400-5500 range and my speed is dropping to 33-ish. I don't care much about the speed drop, but I'm starting to wonder if I should have a 'heavy load' prop since that's usually how my boat is loaded. This last trip I started out with 4 big guys, 3 dogs, 80 gallons of gas and then a ton of camping equipment, beer, food, water, etc. Sometimes it's a bit lighter, but that's pretty average for me. Does it seem like a good idea to you guys to consider propping down for that? I would imagine the solution would be a pitch drop to maybe 13? Or are there other props out there that are designed for pushing heavy loads rather than hole shot or top speed? Or should I stop worrying about lugging it down to the 5500 rpm range most of the time? Thanks for the input.
Nick's Boat
- Boat Model --------- 2275 GCW
- Model Year --------- 2013
- Tube Option -------- ESP w/56 gallon tank
- Under Deck Wave Shield -------- Yes
- Power Option ----- 2013 Yamaha F200XA, 3.3L v6, lowest mounting position
- Prop Specs ---------- Yamaha Saltwater Series II, 15-3/4 x 15P, Polished Stainless Steel
Light Load Specs:
- Performance ---------- 39.5mph @6000 RPM - Elevation: 4,484'
- Loading -------- Light load, 2 adults, ~15-20 gallons of gas
- Notes ------- Optimum trim level was around 1/2. Porpoising would occur between 1/2 and 3/4. Pretty smooth water but not glass.
Heavy Load Specs:
- Performance ---------- 35.2mph @5600 RPM - Elevation: 3,606'
- Loading -------- 5 adults, 2 dogs, ~56 gallons of fuel, 2 massive 120qt coolers, food, water and camping supplies for a 5+ day camping trip.
- Notes ------- Optimum trim was once again around 1/2. No porpoising above that but speed would slip. Slightly choppy water conditions.
