Pittsburgh
Commodore
I did a search on all forums using the keywords shown in Title and found ZERO listings!!! Have To Say I Am Shocked. I have a 2014 Bennington SL21 with a Yeasu 90hp 4 stroke engine unfortunately I tried to take the boat out today only the 5th time this season and after starting engine we I heard a high pitch siren whistle warning noise. I thought perhaps it was the impeller but I noticed there was oil dripping from the engine. I turned the motor off and raised the engine thinking the motor was hit by someone while docked, unfortunately as I raised engine the leaking increased significantly. I lowered motor and leaking came to a stop with engine off. After doing some research I feel the Oil Seals may be the problem. Strange thing is engine only has 145 hours on it. Is it normal that this needs to be changed so soon and should I contact Yamaha once I take it to new dealer as I no longer use the original dealer.
THOUGHTS ??
THOUGHTS ??
