Tooncrazy
I want to install a Lowrance LMF-400 gauge in my 2015 2275 GCW raised helm panel so I can see my Yamaha F150 engine operating data from my already installed NMEA 2000 network.
Right now replacing the tachometer with the LMF-400 looks like my best option space and location wise. The LMF-400 will display tachometer readings and engine hours, in addition to the other Yamaha engine operating data, so I wouldn't be giving up any gauge functions with the swap. There is no other good location for the LMF- 400.
Can anyone here who has installed a LMF-400 on their boat comment on this gauge swap?
The LM F-400 requires a 3 3/8" (86 mm) hole cut out, it looks like the Bennington tachometer might be the same size, can anyone confirm this?
If you did this swap did you have any difficulties with the LMF-400 wiring?
Thank you.
Thank you.
