Storing wet tube
KTurturro
Lake Wallenpaupack, PA
Hi all.
How to others store their wet tube after finishing the day? We have toon storage, at a boat slip and it's a three man, so it's big.
Do you lay flat on pontoon and dry with mooring cover on, bring it home or roll into toon?
Thanks!
I try to end the tubing a few miles from our slip so I can drape it over the stern fencing and let it air dry somewhat. Then I may leave it laying on the floor of the toon if we'll be using it again or if not, I'll just take it home with us. So far this method has worked pretty good for us with no mildew problems. The main thing is to insure air flow above and below if you leave it in the boat.
We just tie it up to our tow bar and air dry it while still inflated. Once it’s dry we stuff it in the center room storage.
We tie it to the tow bar too. If it's still wet, we bring it home.
