Takes long time to fill up with gas.
Tony stephens
Having trouble filling up with gas. It was doing fine then the past two times it seems like it don't get enough air. Is there something I can check? Safety valve or something?
Check your hoses for kinks or a “p” trap in one of the lines. Also, same pump or different pump (handle). Some can be finicky, also some need to be turned a certain way.
Are you filling at a gas station/marina or using gas cans? As Semper mentioned, check your fuel lines for a kink.
Tried different pumps, it's not letting the air escape. The more gas you get in tank the better it gets, but it still takes 20 min to fill up. All hoses are good.
Try the "Enviro" fill tube that you should have gotten when you purchased the boat. Thankfully, I never had to use it but I guess it's supposed to help. Good luck...
Please also check out the other thread posted here:
"Refueling 2012 or newer Benne Pontoon"
