Welcome to Club Bennington
Login Register
Think I'm going to install these for ski/tube towing...
Discussion in 'Do-It-Yourself Projects' started by Spoiledrotten, Oct 17, 2016.
  1. Spoiledrotten
    1,265
    642
    Below the Mason/Dickson Line
    I just don't want to spend $400 to $700 for a ski tow bar, so I got to thinking a little outside the box. If the factory holes in the back stern are strong enough to take on the force of a tow bar that is a couple of feet high, then they are going to handle even more weight force pulling directly back from them, so I'm thinking about two of these; one on each side where the factory holes are. I believe the holes are 3.5" apart, so these should be perfect. Then I can use a 3 point harness with the roller, to keep the weight distributed evenly across the two points of connection.
    Large Stainless Steel Ski Eye, 3-1/2" diameter
    Item # 11898
    Customer Rating:
    ★★★★★★★★★★5 out of 5 stars. Read reviews.
    5.0
    (10)
    Key Features
    • Designed for inboard, I/O, and jet boats
    • 1/2" steel bar with stainless finish
    • Mounting hardware included
    • Mounts through transoms up to 2-1/2" thick
    [​IMG]
  2. mattb
    mattb Well-Known Member
    484
    315
    Central Ohio
    Had one on our bowrider.  Strong, Easy to use.  I've noticed with the tow bar i get some scratching on my motor cowling from rope drag.
    Michiman and Spoiledrotten like this.
  3. Spoiledrotten
    1,265
    642
    I was wondering how the rope affected the top of the motor. I'm thinking that with the setup I'm thinking about, the rope might make a little contact with the sides of the motor just above water level if the skier goes out wide, but I also might string a couple of those small foam noodles on the harness. I was hoping to get some feedback from those with the ski bars.
  4. SEMPERFI8387
    SEMPERFI8387 Moderator
    7,736
    2,088
    York, Pa
    I'd give input, but this is about all I can pull with my 20hp
    [​IMG]
  5. Spoiledrotten
    1,265
    642
    [​IMG]
    adkboater and SEMPERFI8387 like this.
  6. Tooner
    Tooner Well-Known Member
    306
    165
    Florida
    Now that there is funny,
  7. mattb
    484
    315
    Central Ohio
    look up Riverbank video by Brad Paisley for more skiing squirrel, and some other stuff...
  8. lakeliving
    lakeliving Well-Known Member
    6,395
    2,705
    Howell, Michigan
    I love our factory tow bar. One thing you are going to get with that vs the tow bar is the rope will always be pulling you down vs up. I like to think of the tow bar as a mini tower. Worth the money in my opinion.
    Spoiledrotten likes this.
  9. Spoiledrotten
    1,265
    642
    Thanks for the advice, Lakeliving. That's why I'm presenting my ideas here; for feedback on them. That's a good point. Although, I've never been pulled by anything higher then the transom of a boat, so I don't have any idea how it would feel, being pulled from a higher point. Might be something I really liked if I got the chance to try out a tow bar.
  10. adkboater
    adkboater Well-Known Member
    727
    428
    Tylersport,Pa
    If we towed our tube from anything lower than the factory tow bar it'd probably submarine all the time, no matter who's tube we toe if you don't lean/pull back when take off it submarines. It's a dead level  pull with a skier or wakeboard. Oh yeah, it's also perfect to tie the tube to when your done to let it dry.
  11. basshawk84
    basshawk84 Well-Known Member
    54
    31
    East Texas
    SpoiledRotten, not sure where you are located but I have a friend of mine that tinkers with used pontoon boats.  I think he's got a couple of used Bennington ski tow bars.  He's located in Rogers Arkansas and pretty sure he would sell one for considerably less than a new one if interested.
  12. Spoiledrotten
    1,265
    642
    Just sent you a message.
  13. Spoiledrotten
    1,265
    642
    Benny, thanks for the contact. Great guy. He did advise me to get out and just try out the boat/motor to see if it would actually pull me up before I spent any money on the accessories, which is great advice. He doesn't think my boat configuration as got enough lead in its britches to pull me up. So I'll hook up my "Y" harness to the holes in each side of the transom (where the rear of the tow bar bolts), and give it a shot. He said I'd be mighty disappointed if I spent the bucks, installed it, and then couldn't do anything but pull a tube with my boat.
  14. Rockie69
    Rockie69 Well-Known Member
    2,207
    833
    Iowa
    That's a great person right there. Could have just pocketed the cash and moved on.
  15. lakeliving
    6,395
    2,705
    Howell, Michigan
    Maybe there is hope for America regardless what happens Nov. 8th.
    adkboater and Spoiledrotten like this.
  16. Michiman
    Michiman Well-Known Member
    1,139
    471
    Okemos, MI
    Now, let's not get too carried away!
    lakeliving likes this.
  17. basshawk84
    54
    31
    East Texas
    I've known him for over 30 years and he's definitely good people!!
Share This Page
