Bama Kat
With all this talk on speed, at what trim location do you get the most speed? I have always had an I/O and with it you trim it all the way down and then come up just a little as you get planned out. In playing with the toon and the outboard I have found that it turns faster & sharper if you trim it all the way down so the prop raises the back of the boat. But when you just cruising have the gauge about 12 o'clock to around 1 o'clock so the prop is either straight or tilted a little up.
I seem to get the top speed with the trim gauge around 1 o'clock, what is your experience?
