Welcome to Club Bennington
Login Register
Trolling motor
Discussion in 'Helpful Hints from Bennington' started by K C, Dec 1, 2018.
  1. K C
    K C Member
    10
    I am looking to add a trolling motor on my SX21. Can anyone share their experience/recomendations?
  2. Vikingstaff
    Vikingstaff Well-Known Member
    1,143
    1,383
    Go to the top right corner on this forum page and do a search in these forums for “trolling motor” posts. There are a number of good threads on here from some very helpful and knowledgeable people.
    lakeliving likes this.
  3. K C
    K C Member
    10
    Thanks!
  4. Shawn
    Shawn Well-Known Member
    206
    72
    Ohio
    I have a Minn Kota Power Drive V2, 55# thrust and 54" shaft on my 24SLi. I will be moving it to our ordered 21SF as well. It's worked well and moves the boat adequately. 24 volt would be nice but in my case I need to remove the battery to charge since our slip does not have electric and I didn't want to haul two batteries around. I would think that on a 21' boat the 12 volt would be plenty.
    You can get a quick release bracket installed. The bracket stays in the boat but the motor then just slides in and you can remove when not in use.
  5. Oldchuck
    Oldchuck Well-Known Member
    129
    81
    Central Florida
    I would do as Viking suggested and look at past topics. I know Shawn stated that 12 volt should be plenty but that needs to be weighted against how long you want to run. The top speeds will be the same but a 24 volt will last twice as long which is more desirable to many. That is why many trolling guys use 24 or 36 volt systems. They can troll all day and still have plenty left where a 12 volt may be dead after several hours..Again, depends on your need...Read the archives and past posts...
  6. Flying Butcher
    Flying Butcher Member
    20
    19
    Mount it on the side so it doesn't interfere with front gate. works fine with no problems.
    Vikingstaff likes this.
Share This Page
