I have a 2015 Benny Tritoon 22SLX and the blue underwater light is flashing at night. I went through all the instrument panel switches. Anyone know how I turn it off?
It should be switched separately for your navigation/anchor but may be attached to another accessory switch. If it’s flashing I’d assume it’s a bad switch or wiring issue as Link stated.
Do you know what turns them on? if so, see if you can remove one of the wires from that device. If it stops it was probably that, if not, probably a wiring issue.
Hope you're not in SC. State law prohibits flashing blue lights. (Reserved for law enforcement.) No prohibition on solid blue. You may get a ticket if you can't get the straightened out.
